Checking Timing
Old Sep 26, 2000 | 06:45 PM
Matt92RS's Avatar
Checking Timing
I know this is an amatuer question, but isn't there something I have to disconnect other to check the timing?
Old Sep 26, 2000 | 06:52 PM
snakeskinner's Avatar
there should always be instructions on a label under the hood unless the car is very old or it has been removed. you need to disconnect the EST bypass connector. This is a single wire connector that looks just like an o2 sensor connector. It is a tan wire with black tracer and is located in the harness where it goes over the evaporator case near the back of the RH valve cover. have the car pre-warmed, shut the car off and disconnect this wire. then start the car and set the timing, shut it back off and reconnect the bypass connector and you're good to go. This will store a code 42 in the ECM so if you check codes in the future, be ready for it. Kyle
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Old Sep 26, 2000 | 06:58 PM
Vader's Avatar
Matt,
Your connector should be somewhere in this area:
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 10:24 PM
Matt92RS's Avatar
Thanks for the help guys.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
