Cam torque specs. 20ft.lbs??
Old Oct 2, 2000 | 12:22 AM
Mike '91 Z28's Avatar
My memory isn't that great, and I forgot where I put my chiltons . Is 20#'s good enough for the cam bolts? Also should I put anything on the threads to prevent it from loosening? Thanks guys.
Old Oct 2, 2000 | 12:37 AM
Vader's Avatar
Mike,
The spec for a SBC is 21 lb/ft (28 Nm). You do not have to apply a thread locking compound, If you are concerned, you could use a mild Loctite (like 242) or you can get a retainer plate that has locking tabs to secure the bolts.
I;ve never had a bolt come loose on the cam sprocket if properly torqued, but it could happen under severe circumstances, thus the availability of the plate.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
masonta
Sep 1, 2015 06:40 PM
