Question about sealing holes in Headers...
Old Oct 1, 2000 | 07:47 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Since Florida ditched the e-check I cut the air tubes off my SLP headers, tapped the holes, custom cut allen head bolts to the exact length. My question is what should I seal them with? I am thinking High Temp Loctite. Once I get them in I am getting the headers coated with the plugs installed. They look kinda cool, better then blobs of welding slag. Whaddya think?
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 1, 2000 | 09:08 PM
ede's Avatar
ede
napa use to sell brass plug that fit the air pump fittings. find someone with a mig welder and let them weld them shut.
-=ICON MOTORSPORTS=-
Old Oct 1, 2000 | 09:25 PM
Rob P's Avatar
Engine: ZZ4TPI
Like I said, I already tapped the holes, custom cut stainless allen head bolts, I don't want any bi-metallic corrosion (stainless -vs- copper) So welding the holes is not an option. Anyone else?
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Old Oct 2, 2000 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's a different twist on that idea, altho it's still not what you're looking for. You could have a welder close the bottom of the holes up, and then put your custom bolts back in the holes. You'd be keeping the same look.
Hay wait, Restomotive Labs (they make POR-15, the rust-stopping paint) has a new chemical that can actually seal up an exhaust manifold crack! Maybe you want to look into that! Their website is http://www.por-15.com and the product is called Fireseal 2000. You can find it under their "shop online" link.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 2, 2000 | 08:44 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Hey Rob, I did the same thing with my SLP's, however, I didn't use any type of sealant. When I tapped the holes I stopped just short of going all the way through. This way the s.s. set screw locks itself in place when you insert it. Worked great and they have been in there for a little over a year without backing out or leaking.
James
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
