Parts for a 305 to a 383?
Car: 87Z
Engine: ?
Transmission: A4
What parts can I put on my 305 the will transfer over to a 383? Headers, Exhaust, and Ignition is that it? Because, I have the 305 and in the future hopfully next winter to get the 383.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back.
[This message has been edited by new87 (edited October 02, 2000).]
Headers,exhaust and etc should be the same. It depends on what distributor you have, but it should work. The priciples of a 383 and a 305, externally look the same and use the same stuff(other than balancer and flywheel)So most brackets and stuff should also work.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Good luck!
Water pump, timing cover, rockers, lifters, hardened pushrods, timing gear/chain set, HD oil pump, intake (depending upon heads), underdrive sheaves, oil pan & windage tray (not a crank scraper, though), CDI ignition amplifier, large throttle body/airfoil, large tube intake runners, high flow MAF, rtc.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Pretty much everything but the pistons, crank, and heads.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Transmission: 4L80E/4L80E
Depending upon whom you ask, properly sized primary tube headers for a 305 are 1-1/2" - 1-5/8". For a 383, 1-5/8" are torque headers, 1-3/4" are power headers, 2" for serious engines. Therefore, I wouldn't say 305 headers would work on a 383, even though they might bolt on either one.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
I have done alot of 350's, and this is my first 383. I can tell ALOT of pull difference. You will not really rell that much difference in gas mileage, but if you were really after mileage, you wouldn't ask this anyways, right.
But a good torque 383 is better around town and at the track compared to a 350. The next problem you'll have is getting it planted...
