oil pressure problem
Old Oct 1, 2000 | 09:53 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Whem I start my car the oil pressure is at 60 psi.After the engine warms up to 160 or over the pressure drops to 30-15 psi,the warmer the engine gets lower it goes.All this drop is at idle when I start driving as soon as the rpms go over 2000 the pressure goes back up to 55-60 psi.Whats the problem? The oil pressure sending unit is new so thats not the problem.What else?
89 350 TPI,edelbrock intake,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie
Old Oct 1, 2000 | 10:06 AM
Vader's Avatar
E,
What viscosity oil are you using and at what ambient temperature?
What is the total engine mileage?
What kind of oil filter are you using?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 12:30 PM
ede's Avatar
ede
just a WAG but i'd say your nukbers aren't bad. i've saw differant things listed in differant books ,60psi@2500rpm, or 10 psi for so many rpms. lot depends on oil, age and clearances in engine, and the air temp as vader pointed out.
-=ICON MOTORSPORTS=-
Old Oct 2, 2000 | 03:58 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I use 10w40,it has 98,000 miles,and the air temp dos not matter it drops as soon as the engine warms up past 150*.I also use a bosch oil filter.I just changed the oil to 20w50 now pressure will only go down to 30psi instead of 15psi.
[This message has been edited by e-man (edited October 02, 2000).]
Old Oct 3, 2000 | 06:19 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Dont tell me you guys left me hanging!!!
Old Oct 3, 2000 | 09:53 AM
freeze92's Avatar
I wouldn't worry much about the drop. Most small block chevy's drop quite a bit between cruising rpm's and idle. 15 psi at idle will lubricate the engine just fine.
Old Oct 3, 2000 | 09:32 PM
82camaro's Avatar
Car: 82 camaro SC
10 psi per 1000 rpm is a good rule of thumb for a minimum. Your numbers look good.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
