Need help Identifying this thing ...
Old Jul 2, 2003 | 02:03 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
Hello all !!
I have this sensor or sender or something on the passenger side of my engine by the dipstick, between cylinders 6 & 8.
All i know is that when i take it out, coolant comes pouring out.
I believe i need to get a new whatever it is and connector to go with it since they have both kind of dissintigrated. but i'm having troubles identifying what the thing is in the first place let alone where to get it. i was at a GM dealer today, twice, once to get the part i thought it was and then to return it since it wasn't the right part. and when i went back and talked with the guy, he had no idea what it was either.
Engine: 92 L98 B2L pretty much stock everything.
I just am at a loss right now
any help is bery much appreciated
Kyle
Old Jul 2, 2003 | 02:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
fan temp switch... turns on the cooling fan when the head temp exceeds a given value
Old Jul 2, 2003 | 02:13 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
That is your Primary cooling fan switch, not a very good GM dealership if they can't tell you what the part is. There is also another one on the driverside head between #1 & #3 cylinder this one controls the auxillary cooling fan switch for when the car goes over 220* it will kick on the second fan.
Old Jul 2, 2003 | 11:58 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
hey thanks guys !!
i know about the one on the driver's side, it's way easier to see.
will it be killer for the engine/car if it's not working up to snuff?
i have manual switches for the fans hooked and have them running ......
is a GM dealer the best/easiest/cheapest place to get that part?
thanks again,
Kyle
Old Jul 3, 2003 | 07:24 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I would just get it fixed Kyle. Out of sight, out of mind kinda deal. Some auto jobbers may have it, like Napa. I don't think it is a dealer part, plus I don't remember them being that expensive.
Old Jul 3, 2003 | 10:59 AM
oOSpeedFreakOo's Avatar
FS1
part # fs1 its about 2.99 from advanced auto parts i replaced mine after the motor swap but the wire got to close when workin on it and burned the new switch up i now have it in as a plug and the fan run on a switch.
Old Jul 3, 2003 | 12:04 PM
Guest
Guest
Posts: n/a
i'm useing that for my temp gauge but then again i only have a single fan
gta90
Sep 15, 2015 04:00 PM
C409
Sep 1, 2015 03:42 PM
Linson
Aug 21, 2015 02:12 PM
Bob88GTA
Aug 18, 2015 03:31 PM
