LS1 cam question
Old Jul 5, 2003 | 12:35 AM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
LS1 cam question
Will an LS1 cam/lifters work in a 305TPI? If not what are some others beside the LT1 that I could use and get cheap?
Thanks,
Mark
Old Jul 5, 2003 | 02:07 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i am pretty darn sure that LS1 stuff won't work. the ls1 has a diffrnet firing order IIRC.
Old Jul 5, 2003 | 09:24 AM
Ghigman3's Avatar
Car: '87 IROC-Z
ok thanks.
Old Jul 5, 2003 | 09:26 AM
Vader's Avatar
Moreover, the LS-series engines have a larger cam journal diameter, and a valve arrangement like the BBC instead of small blocks - I-E-I-E-I-E-I-E. However, the length is about the same.
Old Jul 5, 2003 | 03:07 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
only 2 things interchange between LS* motors and pre LS
Roller lifters and connecting rod bearings.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
