What Intake for my 350 TBI swap
Old Oct 7, 2000 | 12:59 PM
rsilver's Avatar
I searched the archives and couldn't get a good answer to this. Could you guys help? Which carb or TBI intake manifold is set up for my stock fuel/vacume/EGR/Brake/throttle/
on my 91 RS? I have read about the Holley projection manifold and all the modification
required to make the fuel lines and throttle
linkage work plus it uses a different EGR!!
Is the Edlebrock TBI manifold any better
when it comes to installing the stock stuff?
(I will bore it out to 2" if need be)
Is there a Carb Manifold that will work with my stock fuel lines, Throttle bracket, and all the other stuff that goes on the intake??
I would even consider a stock carb or TBI manifold if there is a decent one out there since i am just doing a base Gm crate 350 swap from my 305. If there isn't a direct bolt on, which one do you think requires the least modification of stock commponents? Sure appreciate the help ....bob
91 camaro RS convert
t-5
open element air cleaner
TBI spacer
Flowmaster muffler
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
