Trick Flow Heads
Old Oct 5, 2000 | 03:01 PM
rage707's Avatar
Trick Flow Heads
I was thinkin bout building a 383 and I saw the posting about the Vortec, didnt seem like a good choice, how bout Trick Flow 23 degree aluminum head? Theyre cheap and seem pretty good. Is a 1.25" spring enough? Also, what kind of cam should I use, id like a rough idle but need power brakes, etc. thanks
Old Oct 5, 2000 | 03:59 PM
Polecat's Avatar
Those Trick Flow's are pretty good heads for the price.The springs are solely dependent on what came. You can have 1.25 springs good to .500 lift, or clear up to .620 lift. I think the springs they have on assembled only go to .480 or .500 lift. But all in all, great set of heads.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Oct 5, 2000 | 04:26 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I've heard alot of good things about these heads.Were going to try a set on my freinds motor and see how they work.I'll let ya know,he is getting them next week.
Superman
Rev'n to Seven
Old Oct 5, 2000 | 04:57 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I just bought a set of the centerbolt ones from Summit. I think they would be perfect for a 383. The standard springs are good for 520 lift. IM having mine bowlported, for less than 900 shipped you cant go wrong.
Good luck!
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Oct 6, 2000 | 05:42 PM
89bonestockiroc's Avatar
I would also like to hear more about these heads. I am thinking about buying a set because the vortec's wont work with my manifold.
Old Oct 7, 2000 | 08:56 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Be prepared to wait 3-4 months for them from Summit.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
Old Oct 7, 2000 | 09:59 PM
FastBroker's Avatar
my 2 cents, I have had awesome results with the Edelbrock Performer RPM 64cc chamber Aluminum heads! about $950, I think... Haven't heard anything bad about them, to date. I wish that the RPM's had a cenerbolt offfering but sometimes the centerbolt covers interfere w/roller rockers, anyway.
Old Oct 9, 2000 | 02:31 PM
Scrams84Z's Avatar
Car: 1984 Z28
Engine: Custom built 383
Transmission: Tremec 3550
I have the Trick Flow 23* heads on my 383 with the 1.47" springs. I have the Comp Cams XE284H-10 cam. Specs: .507 Int/.510 Exh valve lift, 240 Int/246 Exh duration at .050, 110 Lobe separation. Slightly rough idle, but nothing that will shake the car apart. Sounds AWESOME. Wish I had used the SLP 1 3/4" headers with the Borla 3" adjustable cat back though.
'84 Z28 w/ T-tops, 420HP Stroked 383, Trick Flow aluminum heads, Tremec 5 speed, 3.73 posi rear, Edelbrock 750 cfm carb, Dual Snorkel air cleaner w/ K&N filter, Edelbrock headers & 3" exhaust, Edelbrock Strut Tower Brace, Hotchkis LCA's and Panhard Rod, there is much suspension work to come.
"Smoke 'em if you got 'em"
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
