Heat doesn't work, replaced heater core and valve. Its getting cold too!!!!
Old Oct 9, 2000 | 10:14 PM
Rob90TA's Avatar
Hey I am really confused. My vents blow air, but not hot air.
I replaced the heater core (and the little vane that switches between hold and cold is functioning also) and I replaced the valve by the throttle body, and still it won't blow hot air.
Any ideas on what else it could be?
Old Oct 9, 2000 | 11:01 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Check for vacume on the line to the heater control valve. Mine stopped working...and I got lazy...just tapped another vacume line that had vacume full time, and put it on my heater control valve. Now it's toasty all the time. When I move to texas I will probably remove that
Corry
Old Oct 10, 2000 | 09:30 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Check your thermostat it could be stuck. I saw this alot when I used to work as a mechanic.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
