Cam Walk Questions
Old Oct 12, 2000 | 10:24 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Cam Walk Questions
Ok I'm getting ready to install the cam on my new engine and just want to clear a few things up. I'm pretty sure I don't need a thrust button since it's an original roller cam block right? What about one of those bearing spacers that goes between the block and the cam? I know that there is the plate that bolts over the end of the cam with two bolts going into the block, is this all I need to prevent the cam from walking on me?
Old Oct 12, 2000 | 10:38 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Yes Paul, that is all you need for the 87-up OEM roller blocks.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Oct 12, 2000 | 10:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes that's all you need if you're putting a factory-style roller cam into a factory roller block. The retainer plate performs the same function that a roller button does in the first-design roller systems. Unless you have done some machine work to create a space for a thrust bearing, or you are using a timing gear that accommodates it, you can't use one of those.
Old Oct 12, 2000 | 12:17 PM
Car: 89 IROC-Z
Engine: 383
Thanks for the quick answer guys.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
