Blue Smoke from exhaust PLEASE READ!
Old Oct 9, 2000 | 02:53 PM
rondubbs's Avatar
I've had gas in my oil becasue of ground injectors(Edelbrock intake problem)
when the car was finally started after a month or 2 with gas being dumped into the oil, a lot of blue smoke came outof the exhaust.. why?? should i be worried about valve seals, or is it just from the car sitting for months??
ps,,when the gas was in the oil,, the car was never run for more than 5 minutes, so i dont think any damage was done.
Old Oct 9, 2000 | 03:04 PM
JETHROIROC's Avatar
Mine used to blow that puff when it was first started after it set for awhile until I changed the valve stem oil seals. If that's the only time you're blowing smoke, I wouldn't worry about it too much. If it's blowing it while you drive then the gas in the oil may have damaged the engine.
Old Oct 9, 2000 | 03:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Man ,now you got me scared again. Could be valve seals take her out on the highway for 50 miles and come back. Let everything run though. See if anything has changed.
Old Oct 9, 2000 | 06:17 PM
rondubbs's Avatar
could the blue smoke be becasue i am using the wrong gasket on the intake manifold???
the gasket is a felpro one and the color of it is blue,, i was told that it may be the wrong one.. oops
Old Oct 9, 2000 | 06:51 PM
Blade's Avatar
If the gasket doesn't seal properly then yes, it could be sucking up oil from the intake valley, carry it into the combustion chambers where it gets burned up causing it to smoke.
Old Oct 9, 2000 | 07:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I agree w/Blade. I had an Action + on the 396 that wasn't machined right and sucked oil out of the valley. Used a lot of oil and put out a lot of blue smoke. Who told you it was the wrong gasket, and why?
The other possibility is that the gas-diluted oil is/was getting past the rings. You didn't say that you changed the oil - does it still smoke after that, or only when diluted?
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 9, 2000 | 07:22 PM
rondubbs's Avatar
the oil is new and it is smoking blue..
maybe the gas ****ed up the rings
but it was never driven with the gas in the oil! only started, no more than 5 minutes of running.
i was told by a fellow thirdgenner that the blue felpro gaskets are not for aluminum to cast iron applications,, thats why im thinking it might be wrong..
i also pulled the intake up once and when i put it back i reused the same gasket.. could that have messed it up?
Old Oct 9, 2000 | 08:34 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
hmm never heard that gasket statement before. Trickflow recoomends the Felpro 1205 for their heads. Im pretty sure thats a blue one.
Mark Lock
- 86 IROC-Z - My car, mods and ET's
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Oct 9, 2000 | 09:34 PM
My Slow Iroc-Z's Avatar
"i also pulled the intake up once and when i put it back i reused the same gasket.. could that have messed it up?"
What exactly do you mean? If the intake was torqued down then removed then torqued down again using the same gasket then I suspect that the gasket was eighter damaged when the intake was removed or is not sealing properly due to its initial seating during the first installation. Blade is probably right. Try a new gasket and get it right the first time so you won't have to suspect the gasket anymore. I like/use the ROL graphite coated set when I need to join two different metals. The coating allows the metals to expand and contract without stressing the gasket and causing a leak.
Good Luck!!
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, Hypertech 160* fan switch, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 Synthetic 15W50 motor oil, and more to come...
Best ET- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Oct 9, 2000 | 09:50 PM
Iroc_Z28's Avatar
try running a quart of marvels mystery oil in the engine and a bottle in you gas tank and drive it for a while and see if the blue smoke is still comming out....
Old Oct 9, 2000 | 09:53 PM
CamaroZ_85's Avatar
man i wouldnt use ROL gaskets for ****...i work in a parts store that carries them. when you handle a lot of those gaskets you see the crappy quality of them
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 9, 2000 | 10:34 PM
rondubbs's Avatar
ROL gaskets, what does that mean??
Myslowirocz,, what i mean when i say i reused the same gasket is,, i torqued it down once , then reused it,, could the gasket have gotten smaller after i torqued it down the first time , so when i reused it , it was thinner, therefore able to leak??
Old Oct 9, 2000 | 10:53 PM
JETHROIROC's Avatar
I would buy another new Fel-pro gasket and make sure you get the right one for your application. I used to work as an engineer in a chemical company and Fel-pro was all we used on our pumps, compressors, pipe flanges, etc. It's all I use on my vehicles as well. They are good quality stuff, just make sure it's the right one. I'm not sure what they mean by ROL? The gasket you have might be leaking, but if the car only blows oil on cold startup I still suspect the valve stem oil seals.
Old Oct 9, 2000 | 10:59 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
I don't know about intake manifold gaskets, but I know the blue ones (silicone, or something other than cork) are supposed to be re-usable, no prob. I haven't tried it, but I changed my valve cover gaskets over to them, and beat them up a few times trying to get the valve covers back on w/o removing a lot of other stuff in the compartment. Not a leak since!
Corry
Old Oct 11, 2000 | 12:19 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
just clear things up-
smoke at startup and a couple min after- VALVE SEALS/GUIDES
smoke while driving after hot- RINGS/INTAKE GASKET LEAK/PCV PROBLEM...
Steve
Old Oct 11, 2000 | 04:31 PM
rondubbs's Avatar
what about just constant blue smoke? then the car died, and wouldnt restart. the car was sitting for a month or two without being started. what does that mean?
Old Oct 11, 2000 | 04:59 PM
Blade's Avatar
Old Oct 11, 2000 | 05:02 PM
rondubbs's Avatar
the car was never DRIVEN, it idled for 3 minutes with blue smoke puffing all over the place then died...
Old Oct 12, 2000 | 09:30 AM
CamaroZ_85's Avatar
ROL is a brand of gasket
Old Oct 12, 2000 | 02:13 PM
badbird88's Avatar
I went ot my local parts store and they tried to give me those (ROL) and after looking at them for a few seconds I gave them back. My FelPros were on my car for 4 years and they looked like new when I removed them 2 weeks ago and was tempted to re-use them they looked so good but for $13 I got a new set and played it safe.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
chazman
Aug 28, 2018 03:25 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
chazman
Aug 22, 2015 02:01 PM
Linson
Aug 21, 2015 02:12 PM
