Difference between 1998 and 1999 Trans AM's
Old Jul 15, 2003 | 08:17 AM
Steve89GTA's Avatar
Hi All,
Looking at a black 98 trans am.
Can someone tell me the primary difference between the 98's and 1999+.
Thanks,
Steve
Old Jul 15, 2003 | 09:10 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
It's just detail stuff, they all use LS1s from 98 and up. The bodies even look the same.
Old Jul 15, 2003 | 09:13 AM
magn2o's Avatar
The '98 LS1's also had a beefier fuel system.
Old Jul 15, 2003 | 09:21 AM
Tom84L69's Avatar
Car: 84 Z28
beefier? What do you mean?
Old Jul 15, 2003 | 10:49 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The 10th digit in the VIN is different.
Old Jul 15, 2003 | 03:52 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
better fuel system???? not exactly.... what the 98s have that the 99s don't as far as the fuel system go are around 28# injectors and a metal gas tank (meaning you can run a racetronics plug and play fuel pump) , while the 99s have around 26 # injectors and plastic fuel tanks. other differences are that on 98s not all of the gaskets on the front of the gaskets are reusable, but you can put the 99+ gaskets on there... and some of the 98s have borg warner trannies instead of tremec like the 99+...
oh yeah and the 99s are newer
Old Jul 16, 2003 | 05:29 PM
Tom84L69's Avatar
Car: 84 Z28
Borg Warner? Well it's still a T56 right? Tremec bought Borg Warner's manual trans division.
Old Jul 17, 2003 | 03:31 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
yeah its still a T56...
Old Jul 18, 2003 | 03:47 AM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
The 98s' had a single outlet exhaust. '99 and up had dual pipes.
Old Jul 18, 2003 | 05:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
they made a single outlet exhaust when the bumper has a molded spot for 2?
Old Jul 18, 2003 | 07:40 AM
Steve89GTA's Avatar
Was there any difference in the power output and or body style is what I was after...
How about the interior..
Old Jul 18, 2003 | 10:01 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
www.camaroz28.com, mostly fourth genners over there, check it out.
Old Jul 18, 2003 | 01:37 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Strange as it may seem the rear bumber was molded for 2 outlets, but only one pipe emitted from the rear of '98s. Check out some pics you'll know what I mean. Power for '98 and '99 was the same. Trans Ams' were rated at 305hp, those with WS6 checked in at 320hp.
Jorlain
Aug 24, 2022 05:11 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
cRoe4
Aug 7, 2015 08:46 PM
