Car won't start after head and cam swap. Help me troubleshoot.
Old Oct 12, 2000 | 03:36 PM
Mike '91 Z28's Avatar
Okay I just got done putting everything back together from doing a head and cam swap. The first time I tried to start the car it started really rough (I mean really rough) and it died (10 sec) after I let off the accelerator. I felt the headers and they were already hot which made me believe the timing is way off. I adjusted it and still no go(won't even start). Could it be that the distributor is off by 180? (Would the car even start like it did if it was?). Help me out guys.
Old Oct 12, 2000 | 04:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your distributor is one tooth off, in the CCW direction. Pull it out, turn the oil pump drive rod and dist shaft about 30° (1/12 turn) CW, and drop it back in.
Old Oct 12, 2000 | 04:20 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I had the same problem when I did heads/cam on my car.
First - how big is your cam? You will probably have to open up the throttle body plates using the set screw.
Second - quadruple check your sparkplug wires to the spark plugs. Make 110% sure they are in the right order. Make sure the rotor is pointing right at the #1 spark plug on the cap with the engine at #1 TDC.
Those were my problems. I had to adjust the throttle stop screw and I had two wires switched and the distributor was off a tooth or two.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 12, 2000 | 05:16 PM
For your guys information its a LPE216 w/ ~.5" lift. I double checked everything but I'll try to rotate the distro and see how that works. I am also getting a check engine light.
Couldn't I just rotate the distributor instead of the rotor to test if that is the problem??
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
