Min. Air position & IAC, ALDL, A, B sockets??
Old Oct 12, 2000 | 04:06 PM
pvknight's Avatar
Kay, going to clean the throttle body with tpi/intake cleaner or carb cleaner if I can't find the other stuff. After this, reading the article response to a prev. post, I'm going to readjust the idle screw cuz' the mechanic messed it up a bit trying to fix the idle problem. Question is: What exactly am I supposed to do with the u-shaped paperclip? It says to insert the clip into the ALDL in the a and b slots... could someone explain what the ALDL is and wich slots to use? I'm guessing this is some kinda' make-shift jumper to force the iac pintle to extend?
Thanks, Brian.
'91 T/A that doesn't know how to stay awake.
Old Oct 12, 2000 | 06:11 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
The ALDL connector is underneath your dash, to the right of your fuse box. It's rectangular shaped, maybe 1&1/2 inches wide and 1/2 inch tall. It's got 12 little electric connectors, two rows with 6 in each. You want to put the paperclip into the connector, one end in the top right corner spot (slot a) , and the other in the spot directly to the left of slot a (that's slot b). Then turn the key to accessory and you'll know if you've got it right if your service engine light is flashing.
[This message has been edited by ViciousZ (edited October 12, 2000).]
Old Oct 12, 2000 | 06:37 PM
Tom Keliher's Avatar
Here is a great graphic made by my friend in Japan, Tsuyoshi Maeda:
http://plaza13.mbn.or.jp/~firebird/us/diage.html
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
[This message has been edited by Tom Keliher (edited October 12, 2000).]
Old Oct 12, 2000 | 09:59 PM
pvknight's Avatar
Thanks... I new the diagnostic plug-in was always there, didn't know it was called the aldl. However, I don't have a scanner but a local shop is doing free-computer diagnosis service right now, dun ask why, sounds a bit ghetto... heh. Wells, I'll keep ya'll posted, going to clean out the tb this weekend.
Old Oct 12, 2000 | 11:18 PM
Vader's Avatar
Tom,
Maeda T. has a nice site, and is probably a real rarity on the islands with a ThirdGen. That being said, and no disrespect intended, I had to LMAO when I read this line in the instructions:
" Set the parking blake and..."
His data is technically correct, and he has a lot better grasp of english than I do japanese, but it still made me chuckle.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
specialized
Jun 18, 2022 09:26 AM
Todd84Z
Sep 4, 2015 08:02 AM
podiatra
Aug 31, 2015 09:53 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
