700R4 to 383 help please >>>>
Old Oct 12, 2000 | 08:06 PM
MATEOZ28's Avatar
Lastnight I tryed to stab my 700r4 on my 383 heres what I did and what went wrong *I think*....
1) got top dead center and stabbed distributer.
2) bolted on balanced 400 flywheel
3) bolted on torque converter
4) stabbed trans
However the trans stopped about 1/2" away from the block. I started the thread on the bellhousing and tightened them until it pulled the trans mission tight but it doesnt seem right!
Shouldnt it stab all the way?
Am I supposed to put the converter on the trans first then stab it?
If so how do I tighten the bolts?
There are two shafts coming out of the front of the transmission bellhousing and only the inside turns no matter if I change the gears .
Old Oct 12, 2000 | 09:10 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Hey Rafael (remeber me? I was the one at WCG2K without my red '84 Z28 riding with Andy89RS ), what you need to do is install the torque converter in the trans FIRST, then rotated it while pushing it in. You should hear/feel it click three times. This is so that the converter hooks up with the pump and other stuff (sorry, don't know auto that well ) in the trans to make it function right. Then you install it on the flexplate. Good luck.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
YIKESS!!!! Whatever you do, DON'T try to pull the trans up to the motor that way with the bolts!!! You will waste the pump. Quit while you're ahead!!!!!!!!!
You need to pull the trans back out, and put the TC on the trans first. There are 2 slots in the end of the TC hub that engage "ears" on the pump. With the trans laying on the ground, put the TC in it, & rotate while pushing it in; it should eventually go in to where the bolt holes on the TC are about 1" behind the BH flange. When it goes all the way in you'll feel it, and you'll hear a sort of gear sound as you turn it. Then you should be able to "stab" it up in there with no problem whatsoever.
Good luck!
Old Oct 12, 2000 | 09:21 PM
MRZ28HO's Avatar
Engine: was: L69
Ha, beatcha to it RB , but you added info I forgot. Hey RB, since your in So-Cal now, why not join the two clubs in my sig (SCFB and SC3GFB)? Maybe we can hook up and I can finally check out that 400 beast of yours.
[This message has been edited by MRZ28HO (edited October 12, 2000).]
Old Oct 12, 2000 | 09:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Before you try to put it again, you should probably check the pump as mentioned, and you might have also torn the seals.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, HEI Distributor w/ Adjustable Advance, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Oct 13, 2000 | 01:21 AM
MATEOZ28's Avatar
Good news everyone!
I BROKE MY TRANSMISSION
I didnt notice the two damn teeth *or whatever* on the tip of my converter. By forcing the transmission on when I threaded the bolts I broke one of the teeth on the shaft that connects to the converter!!!
Anybody know how much that piece will cost?
And yes I remember you bro! Give me a call
(559) 261-2514
RAF
or I'll call you I need some advice
THANKS MAN!
Old Oct 13, 2000 | 02:11 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I have a question. On a 383 are you supposed to use the 400 flywheel or the standard 350 one? I had my rotating assembly balanced with a 350 flywheel.....did I make a mistake?
Old Oct 13, 2000 | 08:18 AM
FastBroker's Avatar
383 is 350 w/400 crank that is externally balanced. Need the 400 flexplate, my man. Did you start the engine w/that flexplate? Probably vibrate to pieces, no?
trans problems: Call the trans shop or bring the tranny right to the shop. They will give you an estimate and it should be a one-day turnaround for you.
Old Oct 13, 2000 | 08:31 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Paul and FastBroker, it depends on the crank design for the rear seal. Many 383 cranks are not 400's, but custom made for the 1pc or 2pc seals. For 1pc rear seal cranks, you use the 350 flywheel for a 1 pc crank. The bolt pattern on the crank and flywheel is smaller than the crank/flywheel pattern on a 2 pc rear seal setup. So if somebody is using a 400 crank (2pc rear seal), then they use the 400 flywheel.
Some machine shops will remove and/or weld in new balance material for the 350 flywheels to help achieve balance as they do the rotating assy.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
[This message has been edited by KevinP92Z (edited October 13, 2000).]
LT1Formula
Oct 8, 2015 08:34 PM
6998poncho
Sep 25, 2015 02:56 PM
