Knock sensor and Coolant Temp switch
Old Jul 18, 2003 | 08:21 AM
robs92rs's Avatar
I was wondering if any one knew of any new locations on the block that I could re-locate the knock sensor and coolant temp switch. I have Hooker super comp headers and they are too close to the connectors on the drivers side, so I need to re-locate them. Any ideas?
Old Jul 18, 2003 | 09:44 AM
ede's Avatar
ede
passanger side
Old Jul 18, 2003 | 12:15 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
knock sensor is right above oil pan on pass. side, cooling fan switch is in passenger side cylinder head towards the firewall.
Old Jul 18, 2003 | 01:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Fan switch is right between cyl. #6 and 8
Old Jul 19, 2003 | 09:52 AM
robs92rs's Avatar
I know where the sensors are originally, I want to know where are some other places I can put them.
Old Jul 19, 2003 | 09:26 PM
RICHRAD's Avatar
Couldn't you locate them in the fitting openings of the intake water passages?
Old Jul 21, 2003 | 06:38 AM
robs92rs's Avatar
I will have to check it out, I can't leave them where they are at now, I was thinking that the knock sensor would have to be on the block, I am hoping there are some plug holes on the drivers side that I could install them.
Chuck84TA
Jul 15, 2016 09:05 PM
Bstrang6
Sep 8, 2015 04:29 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
