Rear main seal conversion?
Old Jul 18, 2003 | 10:31 AM
smithtc's Avatar
I've got a stock 509 casting 400 2 bolt main engine.
I also have an 89 350 block ready to go to machine shop shortly.
Wanted to make it into a 383 with ~375-400hp at the crank @ 5000-5500 rpm and ~500 torque at the crank in the 3000 rpm range give or take.
Thinking of using the 400 stock crank in the 350 block. It'll need a 2-piece to 1-piece rear main seal conversion (anyone recommend a source for this). Has anyone done this? Is it cost effective? Any problems with this idea?
Later on I want to make the 400 a high horsepower high rpm screamer, so I plan to buy a new crank for it. Don't want to waste the crank, might as well use it in the 383.
Old Jul 18, 2003 | 11:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't done it, but here's a source.
http://www.competitionproducts.com/page61.html
By the time you get your crank machined and buy the adapter, I'd think you could buy a new 1-piece 3.75" crank (assuming you sell the 400 crank you have).
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
