Rearend is acting up.
Old Oct 13, 2000 | 09:29 PM
91_LHOV6's Avatar
My car was fine until I replaced the cat with a straight pipe. Now, every time I take off with any force the rearend or tranny pops with such force that it jars me. It also does this when shifting to second. It is an automatic. Does anybody know what could be? When I say taking off with force, I mean pushing it about a 1/4 of the way down. Oh yeah, It's a V-6.
Old Oct 13, 2000 | 10:46 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
First off I'd say check the tranny mount. Just in case, its at the tail end of the transmission, there is a stel crossmember held on w/ 4 bolts, plus the one for the tranny mount, remove 'em all, if the rubber seperates from the steel seat, the mount is bad, if the rubber is loose, the mount is bad. (I had one die because the knucklehead owner before me didn't use locktite on the trans mount nut...) When mine died, I could feel the transmission hit through the center console.
If the rear end is bad, it should make a constant clunking that increases w/ rpm.
I have never experienced bad U-Joints on my driveshaft before so I am not sure what that actually feels like, but I know when shifting into drive, or reverse it can cause a clunk.
Hope it isn't anything serious!
Corry
Old Oct 14, 2000 | 12:19 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
On my car when i had bad u-joints, I could put it in Reverse or Drive from park and it would clunk, plus jar the driver and any passengers. (not good for that hot date on friday night) Myself...I could rotate the driveshaft with ease....Right now mine is as solid as a rock.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-Future:
-383 Stroker?
Old Oct 14, 2000 | 01:11 PM
91_LHOV6's Avatar
Yeah, I feel it hit in the console, right behind the shifter. It doesn't do that when I ease off from a stop or shift to drive or reverse. I'll check the mount. I have a friend with a '92 who had to replace his. Thanks for the info.
Old Oct 15, 2000 | 03:35 PM
Biochem's Avatar
Car: 2002 SOM z28
Check your torque arm bushing too. Mine is shot and it makes a thud sound when I get on it and it shifts... Go poly urethane for that one, stock rubber for the tranny mount.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Z28/ZR1
Oct 23, 2015 01:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
loud91rs
Oct 5, 2015 10:05 PM
Giocio
Oct 1, 2015 12:20 PM
ironbmt
Sep 27, 2015 06:00 AM
