Code 34 on 350 TPI
Old Oct 14, 2000 | 11:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Code 34 on 350 TPI
Tonight I started up the car and it idled then died. Started it up again and it died. Tried it again and it idled finally then popping up a 34 for about 15 seconds then the Light disapeared. MAF Bad? TPS is at .54
Old Oct 15, 2000 | 03:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
bttt
Old Oct 16, 2000 | 12:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check and clean the connectors, wires and relays.
You could also measure the outout voltage from the MAF to se if it's working. I think it is the B and C connectors (..dont remember...) I'm sure someone else can give you the numbers..
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
