Wheels squeel when I turn.
Subscribe
Jul 19, 2003 | 10:45 PM
Reply 0
Jul 20, 2003 | 12:26 AM
My only squel when i turn the wheel almsot all the way and im going slow....
when do yours do it?
Reply 0
Jul 20, 2003 | 01:02 AM
Reply 0
Jul 20, 2003 | 03:27 AM
Quote:
Originally posted by joshwilson3
They do it all the time when I turn left or right. When I turn the wheel all the way to the left or right, it feels like I am grinding something. Like I have a flat wheel and is boucing and grinding real hard. Do you think all of this would be caused by bad wheel bearings or something else?
Does it do it when the car is stationary, and you turn the wheel full lock? If so, you may just be low on power steering fluid. The pump is supposed to make a little bit of noise at full lock, as it has a pressure relief valve. Either that or maybe the pump belt is slipping a little. Try tightening the power steering pump belt
If it's only when the car is moving, then one thing to check for is wear on the inner wheel arch. I fitted some aftermarket alloy wheels and the offset was wrong, causing the wheel to rub on the inside of the wheel arch. Felt like a grinding as you described.
Reply 0
Jul 20, 2003 | 06:42 PM
Reply 0
Jul 20, 2003 | 06:51 PM
get someone to look a check where the noise is comming from when your moving slowly, if it does under 5mph , try this...
my car does the wheel squeel too, like if its turning too much and one is being drag!? weird noise, might be the rear tires i dont know, but for a big long car like this i think they turn very tight! not like jeep, but still for the size its great.
Reply 0
Jul 20, 2003 | 07:16 PM
some one told me that is was normal for are cars to make a noise when we turn the wheel hard.
Reply 0
Jul 20, 2003 | 08:30 PM
Quote:
Really? Like the noise he's describing?
Reply 0
Jul 20, 2003 | 08:52 PM
ya the squeeling sound, my car does it when i turn it really hard almost to the end so i asked my mechic and he told me it was normal for are cars. i could be wrong i am just telling what my mechanic said.
Reply 0
Jul 20, 2003 | 08:58 PM
I think that might be the power steering pump relief valve in that instance. I could be wrong also though
Reply 0
Jul 23, 2003 | 12:58 AM
well my car only squeels when i've got it too full lock or close and im going slow, like sharply pulling into a parking spot. Other than that its fine.
Reply 0
Jul 23, 2003 | 01:17 AM
when i crank the wheel full over it squeals, its because of the pump tho
i never crank it all the way at a dead stop, thats a no no
Reply 0
Jul 25, 2003 | 08:21 PM
May just be bad tires - sidewalls caving in under the pressure of the turn.
Reply 0
Subscribe
