Battery Reloc. / MSD connection ?
Old Oct 16, 2000 | 10:34 AM
Brett's Avatar
I'm probably going to relocate my battery to the trunk and use that spot for my PCM until I install the blower. My question is where can/should I hook up the MSD box power wire?
I haven't looked into relocating the battery much yet. What are some tips on how best to set it up? What gauge wiring should I use to run from the trunk to the engine bay? I'll probably go get a new Optima for this. Should I use a battery case like what's required for NHRA?
1991 RS LT1
every imaginable bolt-on, ungodly LT1 355, and 12 pounds of intercooled boost on it's way in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, first run 13.056 @ 109.52 stock
"So what DOES the back of a Mustang look like?"
Old Oct 16, 2000 | 12:46 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have my power wire going to my Alt.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.2@98
Old Oct 16, 2000 | 01:32 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I mounted my battery in the trunk of my convt on the driver side (wife wouldn't let me ditch the spare tire!). I used the Moroso Box to keep everything legal at the track. It's vented and I have the battery cut off switch mounted behind the license plate. I used like 01 or 00 cable. I ran a hot to the starter and a negative all the way to the front of the car/engine, plus I took another ground to the back part of the car. Subframe cars can have problems. My 6AL box is mounted on the driver side next to the brake booster, when I swapped to a stand alone wiring harness for my L98 swap I ditched the fuel/fan relays that used to be there. Not sure where I stole power from for the box, can't remember.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 16, 2000 | 01:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have my power wire going to the starter motor. The MSD instructions mentioned that as a good spot. They also wrote not to wire the MSD to the alternator, but I don't know why- it didn't make sense, since the alternator goes to the battery.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
