350?
Old Jul 20, 2003 | 04:35 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
350?
I have a 350 from a 94 blazer. I know that is not a vortec motor but was curious if any body might know a little about the engine.
Would an lt1 cam be effective, are the heads any good meaning would a port and polish job see any real gains. I may rebuild it to take the place of my worn 305. Any 350 has to be better than that motor and I don't want to get into alot of $$.
Any help would be apreciated.
Thanks Scoty
Old Jul 20, 2003 | 04:44 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
find the casting # and go to www.mortec.com
It'll tell u whats what
Old Jul 20, 2003 | 05:19 PM
boogie's Avatar
If it is the original untouched engine it has 64cc swirl port heads(crappy 193 castings) and dished pistons that yield a 9.1 CR. It has a pitiful flat tappet cam. Most of these blocks are machined to run a factory hydraulic roller setup but not all. Chances are good you can run the LT1 hydraulic roller cam but i would pull the intake and make sure before gathering parts. The LT1 cam would be an improvement over the original but its a mild cam...depends on what you want to do.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
