balancing a short rod stroker
Old Jul 20, 2003 | 08:17 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
since i am going to be buying new rods for my 350 build up, i figured i might as well go ahead and grab a stroker crank as well
i'm going with 400 rods, so i dont need to buy new pistons or worry about doing heavy clearancing
i already have a matched set of sealed power hyper flat-tops
i am also planning on buying a matched set of rods
what sort of stroker crank (internally/externally) will i need to be looking at here to do the least amount of clearancing?
i am guessing since i am using factory parts except for the crank, i dont need to run a small base circle cam
also, when i take everything to get balanced, what will i need to bring with me and about how much should it cost me?
btw, this is for a 2 piece rear main seal block, i might also like to run either a T56 or T5, so what kinda flywheel will i need?
also what balancer will i need?
Old Jul 22, 2003 | 08:51 PM
ok, i found out
i need an external balance crank cuz i am using short rods
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
