PLEASE HELP TRANNY TROUBLE!!
Old Oct 14, 2000 | 12:31 AM
Metallica383's Avatar
I have a 700r tranny and it started acting up a few days before it would not hardly shift from 2nd to 3rd without hammering it and then I would only shft from 2nd to 3rd if you did it manual and it got to the point to where it would not shift into 4th period and now all gears are gone except 1st and Reverse is the tranny gone or what?
Old Oct 14, 2000 | 12:02 PM
Blade's Avatar
We DO have a tranny forum you know...
Old Oct 14, 2000 | 01:45 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
SOunds like it. I do not know the internals of the transmission, GMTech could proabbly tell ya exactly whats wrong. I had a performance rebuild done on mine. My oump (both halves), and my torque converter died. Thing would stall when it came to a stop. They replace the TC, and pump, put the vette servo in, "hemi packed" the clutches, put the overdrive valve in (so it'll shift into OD at wide open throttle). The thing rocks now, it was done for $1600 the only down side.
Good luck
Corry
Old Oct 14, 2000 | 06:56 PM
BLADE,
I see you dont know nothing about a tranny so **** OFF!!!
thanks and have a nice day
Old Oct 16, 2000 | 10:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with Corry (and Blade!), the trans needs a rebuild.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 16, 2000 | 12:42 PM
Is it just me but BLADE did not say anything of any importance about the tranny other than a smart *** remark although I thought the tranny needed to be rebuilt but I am not expert on transmissions so I thought that I would ask some people who might no.
Old Oct 16, 2000 | 05:38 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
sounds like a main clutch failure.. usually the first thing to go on 700r4's (i hate theese trannys) symptoms of complete failure are when shifting out of first there is no drive range (feels like you stuck it in nuetral) 1st and R being your only gears.. its happened to me twice with two different trannys, and everytime the same thing, same diagnosis everywhere i go.. look at a low mileage junkyard tranny, youll cry at the cost of repairs...
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
mrbird
Oct 20, 2015 03:43 AM
bjpotter
Oct 4, 2015 07:48 PM
Lmancha96
Sep 25, 2015 08:11 PM
IROCZ1989
Sep 4, 2015 11:54 AM
