why cant i get my car to run any cooler than 200 to 220
Old Oct 16, 2000 | 11:17 PM
Onefastcamaro's Avatar
the only time i can get it to run any cooler is at night when its real cool out on any day even 70 degree days it runs 200 to 220 and even 230 sometimes ive got a new factory radator new water pump 50/50 mix tried several different thermostats i have 160 stat 160 fan switch ive got my bottom air dam i put a 87 tpi in my 92 rs and still got my single rs fan would the iroc dual fan help much? any other ideas? please help mods below ive had this motor in my car for 1 1/2 years now always been this way
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lca's
comming soon NOS
Old Oct 16, 2000 | 11:21 PM
IrocManiac's Avatar
Mine does it. You can get your fans to turn on earlier and get a lower thermostat.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 17, 2000 | 12:39 AM
ive got a 160 thermostat and 160 fan switch??
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lca's
comming soon NOS
Old Oct 17, 2000 | 03:36 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Your water pump is probably a OEM style replacement pump from a local parts store right? Probably rebuilt, and even if brand new they're lackluster.
If so try running a good name brand hi-flow water pump.
Stewart was one for around $69.99, Stage 1 pump. I'm running that and it made a noticeable difference in how cool mine runs. Will still overheat if I have to sit in traffic where I'm at a complete standstill for long periods of time (my fans are about shot). But if I am moving at all, getting some airflow it never even gets over around 175ish degrees. Prior to the pump I was running at 200-220ish even on the highway and burning up in any kind of traffic...
I ordered mine online here : http://www.stewartcomponents.com
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Oct 17, 2000 | 10:08 AM
Biochem's Avatar
Car: 2002 SOM z28
I feel your pain! I too was running pretty hot on both long trips or if I sat in traffic. I even got dual electric fans that are both on and a 160F thermostat... and the Stewert pump! I think my underdrive crank pulley isn't helping matters, but I don't think it is causeing all my overtemp problems either.
There is a post about a guy who changed his plugs and increased the temps quite a bit. This is something I have wondered about too with my car.
Right now, it is so cold out, that I actually am going to swich back in my 190F thermostat and place one of the fans on a switch because I am running too cool... go figure.
BTW- Running too lean will cause hotter temps too. Flushing the radiator may help. There is some additive to the radiator fluid that is said to drop temps a lot... water wetter or something like that. Sometimes adding an oil/tranny cooler will help a lot too... those can't hurt either on a normal engine.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
[This message has been edited by Biochem (edited October 17, 2000).]
Old Oct 17, 2000 | 04:01 PM
89IROCZ
Guest
Posts: n/a
My car used to run at 190 or so and then it started getting a little hot all of the sudden, even on the highway. It would get up to 220 very often. It progressivly got worse over the next two weeks untiil sunday.... it got to the point where I'd drive the car for 3-4 min and the water would be boiling. So i changed my thermostat.... i had a 180* and I wanted to go to a new 170*, but I couldn't find one. So I got a new 180* stat and it runs around 190 again.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
