Header /brake line concerns....should i worry?
Old Jul 22, 2003 | 09:21 PM
RICHRAD's Avatar
Have bent these as far as possible with hands, but should I see how much more movement I can get with the pliers....
Attached Thumbnails Header /brake line concerns....should i worry?-brake-line.jpg
Old Jul 22, 2003 | 09:45 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
i would use some metalic raps that we have in the kitchen for BarBQ cooking, just around them, maybe... might be a good idea.
if you have any of thoses "laser" temp gun, you could see how hot they go.
thats close yes, but when you bend them, check where the fitting are , you will need to hold the line so it bend higher than there, it might crush the line a bit a the fitting if not carefull.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
