Have 2 tiny problems with my L98.
Old Oct 16, 2000 | 10:12 PM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
1st, when i go to start my car, when i 1st turn the key, before it even makes the engine crank, it makes a twitching sound that seems to be comming from behind the control stick that turns on the head lights, or somewhere behind the speedo. Im thinking my ignition?
2nd, when im going down the road a high pitched squelling is comming from my left front tire, and when i apply the brakes even slightly it will stop for a few seconds. Any ideas? i know its something to do with brakes. But problem number 1 is what im not to sure about.
1991 Z28 Camaro L98
5.7 T.P.I. (350)
http://www.bright.net/~rwig/BandetZ28.jpg
http://www.bright.net/~rwig/BandetZ28-2.jpg
Old Oct 16, 2000 | 11:40 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The squealing is probably your front pads need replacing. There is a little piece of metal (wear indicator) that rubs the rotor when they are getting low. Don't forget to get the rotors turned.
The noise in the dash...does it come on before you turn it to start??
Does the buzzer work??
Does it go away after you start it??
I've actually seen a key buzzer that was no good make a weird, fast sound. Could be called a "twitching" sound.
Lay under the dash and look for the noise.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 17, 2000).]
Old Oct 17, 2000 | 05:18 PM
KamaroZ350's Avatar
It comes right as i turn it, and when the engine starts to turn it stops.
Old Oct 17, 2000 | 06:55 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
In would stick my head up under the dash while its doing it.
If it is coming from the dash area you should be able to pinpoint it.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
