hissing plugs?
Old Jul 23, 2003 | 12:42 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
hissing plugs?
I just finished putting in 8mm wires and new plugs. When I shut the car off it hissed for about 5 seconds. I think that a cylinder is bleeding off compression, but am worried as to how tight to tighten the plugs down. Would would you recomend for me to do?
Old Jul 23, 2003 | 12:52 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
It sounds like it's your Air condioning system equalizing pressure.. Normal thing if it is
Old Jul 23, 2003 | 09:50 AM
Vader's Avatar
Tapered seat plugs should usually be torqued to 18-20 ft/lb in iron heads, 12-15 ft/lb in aluminum heads.
Old Jul 24, 2003 | 12:50 AM
Engine: L98 and L03
I thought I turned the A/C off, but didn't and didn't think to check it either All is fine, just a false alarm.
Old Jul 24, 2003 | 06:46 AM
gmsmallblockguy's Avatar
heh heh Well for future reference minor damage to the plug sealing surface is common on aluminium heads and can be corrected with a little GM Black Hi tack sealer.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
