Code 53?? what the hell??
Old Jul 23, 2003 | 03:06 AM
KiLLJ0Y
Guest
Posts: n/a
yep thats what i said.. code 53!!
heres the scoop.. i parked my car for a week.. didnt touch a thing on it. it sat for just over a week, i try and get in today to start it and ... nothing... no click.. no engine trying to turn... nothing..
the lights are on, the stereo works, gauges all work.. when i try to start the car.. the radio dims as usual.. i pull the headlights on and turn the key.. they do NOT dim..
so i notice the SES light is on.. i pull the code... first it gives me code 12... naturally... i wait for the other code.. and it flashes 5 times.. then 3.... code 53??? what the F---???
fuel pump is pumping, all the fuses are ok.. all battery connections are clean. i have tried a push start because i have a bum knee and i dont have anyone else to help me. anyone know what the hell is going on with this car??
was running fine when i parked it. now its being gay.
Old Jul 23, 2003 | 09:57 AM
Vader's Avatar
Have you tried a battery charger or starting booster unit on the car? Normally, a '53' is the result of a voltage spike, which can also blast the MOV in the ECM. Booster units can deliver over 17.1V, triggering the '53' code.
Old Jul 23, 2003 | 10:25 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
charge the the battery if necessary (off the vehicle) and reset the ecm. if you do remove the battery from the vehicle, then the ecm will reset automatically(given it's off the car for a few minutes). if the battery is charged and no charging ti required, then remove the pos(+) battery terminal for 5 min reconnect and try firing her up.
Old Jul 25, 2003 | 03:51 AM
KiLLJ0Y
Guest
Posts: n/a
thats some good info... i'll try that...
you know... now that i remember correctly.. my dad did try to recharge my battery 2 weeks ago... and didnt un-cap the battery.. and some acid leaked...
i'll try whats you guys recommended on saturday.. gotta go to the Angeles Game tomorrow night.. thanks for the help, ill let you guys know what happend..
do you think i should get a new battery?
Old Jul 25, 2003 | 07:41 AM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
Considering your father had to charge it before...I'd say yes. Couldn't hurt nothin, and at least you know you have a good battery for a few seasons.
Old Jul 29, 2003 | 03:53 AM
KiLLJ0Y
Guest
Posts: n/a
ok boys.. i did everything you guys said... put the keys in.. turned it...
nothing.. no click no crank... nothing
all lights come on.. the headlights dont dim when i try and crank it. stereo is on.
did i kill the coil on the starter? im running out of things it can be. any one have any ideas?
Old Jul 29, 2003 | 07:59 AM
Vader's Avatar
Time to start checking the starter circuit (and cleaning up the acid that was boiled out of the battery).
Likely suspects are the neutral/clutch safety switch, VATS/start enable relay, igition switch, or starter solenoid.
Old Jul 29, 2003 | 12:42 PM
KiLLJ0Y
Guest
Posts: n/a
yeah i'll get out my wire tester and see whats getting current and whats not.. i have a feeling its going to be the starter... but i'll check everything anyways.
i'll get to it on saturday,i just had knee surgery, but i'll keep you guys posted if i have any questions,
thanks Vader,fakeyankee,mystikkal_69
dave
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
