Need help with compressor!
Old Jul 23, 2003 | 11:37 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Ok, I just charged my AC with some R12, and I thought that would solve my problems. But it still doesn't out out cold air. I noticed that the clutch(it's that triangle thing, right?) on my compressor only engages for a little bit and then it slips. Should this be happening, and if not, then how can I fix it?
____________
85 z28 305 4bbl carb
Old Jul 23, 2003 | 10:00 PM
Vader's Avatar
Your low pressure cutout on the accumulator is probably shutting off the compressor after it suck the low side down. Chances are, you need more refrigerant, but use a gauge mainfold to monitor pressure when you top it off.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
