No start but lots of lites ...HELP!
Old Jul 24, 2003 | 09:39 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I am having an electrical problem right now and can't start the car. The car lites up but does not turn over. I have replaced the starter and ignition switch. I have found a dead wire leading from the neutral safety switch which is yellow. It has no power and I think this is the problem. How does the safety switch get power? Do you have any experience with this problem?
Old Jul 24, 2003 | 09:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The safety switch doesn't "get power". What happens is, when the key is turned to Start, power is supplied by the ignition switch to the yellow wire; it passes through the safety switch if it's in the "safe" postion, to the purple wire; the purple wire goes to the starter solenoid.
Old Jul 26, 2003 | 09:47 AM
Axle/Gears: Posi
Thanks everyone. I am on the road again. It was the purple wire leading from the Neutral safety switch to the starter. What a pain the the ...
Old Jul 26, 2003 | 10:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
86White_T/A305
Aug 17, 2015 12:16 AM
