89 roller 350 heads
Old Jul 24, 2003 | 10:20 AM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
89 roller 350 heads
i might be getting a roller 350 which i think came out of a van. what kind of heads did these engines have? i didn't see the marks on the front of the heads or the casting #s. there was also an 89 truck with a roller 350 in it. on the front of the heads it had 2 diagonal lines about 1/8" thick and 1/2" long about 1/2" apart what heads are these? how good do these heads flow compared to 041s? thx
Old Jul 24, 2003 | 12:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If the engine came from a G20 van, then more than likely they're the 191's or the 193's.
Go here. There's a link in there about what can be done to those heads.
https://www.thirdgen.org/techbb2/sho...hreadid=192114
Old Jul 24, 2003 | 01:31 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
GM didn't put roller cams in trucks & vans until 1996.
Old Jul 24, 2003 | 03:10 PM
AJ_92RS's Avatar
True. But they did put blocks that can take a roller cam.
Old Jul 25, 2003 | 12:31 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I put a set of 041s on my truck to replace the 193s, the difference was astounding. Do THAT!
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
