Tach Problem
Old Oct 17, 2000 | 10:31 PM
CamaroX84's Avatar
Tach Problem
I have an 84 Camaro with the LG4 carbed motor. I just took out the tach and put in one from a later model IROC with the 5500 red line. I noticed that the IROC tach seems to be real sloppy. The motion on accelleration is not very smooth, and when I decelerate, the needle just drops in a strange way. My old tach worked just fine. What can I do to fix this? Any help would be much appreciated. Thanks.
Old Oct 18, 2000 | 06:06 PM
ede's Avatar
ede
sure you have all your eletric connections tight? factory tachs aren't known for being the best pieces.
-=ICON MOTORSPORTS=-
Old Oct 18, 2000 | 09:07 PM
merf23's Avatar
you can use your original tach and swap face plates. use a dremel tool to grind the rivets off the back then epoxy it in on. The pointer will just pull straight off, be careful, they are a bit delicate.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
