Stumbling at highway speeds and a code 41--->
Old Oct 17, 2000 | 10:59 PM
MatchboxTransAm's Avatar
Well, My TA sometimes stumbles at highway speeds but not all the time. At first I thought of the fuel filter(cheap fix if the problem). No good. Then I pulled a code 41, which gave me 3 options. I went out and picked up a new distributor cap, rotor, plugs, and wires. Still no fix(but probably needed it anyway) . Anyone help? Thanks in advance. I'd really appreciate it. Here is some info for those of you.......
1983 TA 305 LG4 carb
Jon.
Old Oct 18, 2000 | 07:42 PM
Anyone have an idea? I really could use some help. Thanks again, Jon.
Old Oct 18, 2000 | 10:18 PM
84IROC's Avatar
sounds like a weak fuel pump, it will usually show on the highway first, my book also states that the MAP/vac sensor could be giving bogus info to the ECM......
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
[This message has been edited by 84IROC (edited October 18, 2000).]
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
jbd1969
Aug 17, 2015 07:06 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
