My Compression Test
Old Jul 25, 2003 | 05:54 PM
Naphead's Avatar
My Compression Test
Ok I just did a compression test today and was wondering if it was alright?
1 - 168
3 - 163
5 - 165
7 - 170
2 - 170
4 - 170
6 - 180
8 - 175
They seem a little off, but is that bad?
Ok, here the problem w/ my car, my 0 - 60 is pretty good but not the best, anything above 60 takes forever, and just eats up gas.
The idel is rough, when sitting in the car you can feel it shake pretty baddly. The car never ran perfectly since I got it. It also runs a little rich.
Heres some stuff I tried to fix the miss:
new fuel pump
changed carbs 3 times(all CC)
fixed all broken vaccums
new o2 sensor
changed carb agian to Non CC and changed distributer to vacume
changed ignition coil
tune up(plugs, wires, cap, rotor, oil, pcv, filters, ect...)
Well thats all I can think of, you guys have any ideas?
Old Jul 25, 2003 | 07:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yo Nappy,
May want to list what type/year/etc/ car you have
BTW, compression test results are fine, nothing to do with what problem you think you have.
Old Jul 25, 2003 | 07:45 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
know the cam specs?
my car ran like dog ****, poochy as hell, thought it was running lean, turned it up, turns out it was already real rich, couldn't get the edelbrock to run right, the demon on it now makes it haul
Old Jul 25, 2003 | 08:18 PM
Naphead's Avatar
LoL sorry about that, I forgot all about it.
anyways, its a 84 Trans am 305 lg4
Old Jul 26, 2003 | 04:26 AM
ede's Avatar
ede
i'd look for a restriction in the exhaust, clogged cat maybe.
Old Jul 27, 2003 | 10:10 PM
Naphead's Avatar
I just put on a new exaust, so it cant be the cat. What about timing chain? could that be a problem? if so is there an easy way to test it?
Old Jul 28, 2003 | 08:39 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If it never ran well since you have had it...have you checked the plug wires for proper routing?
Timing chain shouldn't cause a rough idle, unless it's really slapping around.
Old Jul 28, 2003 | 11:15 AM
Naphead's Avatar
All the wires are in the right place, LoL I have no idea what else I should look at.
Old Jul 29, 2003 | 11:58 AM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
Re: My Compression Test
1 - 168
3 - 163
5 - 165
7 - 170
2 - 170
4 - 170
6 - 180
8 - 175
new fuel pump
new o2 sensor
lol...my compresion test results were between 125-138 psi..now thats bad
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
