Guy's what size vac hose do you have running off of your map sensor?
Old Oct 18, 2000 | 09:37 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I noticed the one on my friends car is plastic and alot smaller then mine, mines fit's on the nipple nicely, his is big then get's smaller, does it matter what size it is? does it make a diffrence in performance? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 18, 2000 | 10:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
It reallly doesn't matter as far as what is better/needed.
As long as the line isn't old and colapsing on itself it will be fine.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 18, 2000 | 11:39 PM
Ratnose86SC's Avatar
Yeah mine was plastic till it broke and i just used a regular thick line.
I guess it works fine.
9192camaro
16
Feb 3, 2019 12:21 AM
92purpz28
Aug 11, 2015 02:30 PM
knight72
Aug 10, 2015 09:32 PM
squiggy2
Aug 9, 2015 09:30 PM
