Re-tapping aluminum manifold
Old Jul 26, 2003 | 04:33 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
My edelbrock performer intake has a bolt hole that feels stripped...the on that holds the distributor down, is there a special way to re-tap aluminum or can i just do it as normal? THanks
Old Jul 26, 2003 | 04:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
personally i would just buy a heli coil kit drill it out retap and insert the coil and put the origional bolt back in.. should be able to get a kit for under 10 bucks at any autoparts store.. as for a special way to do it... theres none that i know of.. its just like tapping steel except a lot easier due to the softer metal
Old Jul 26, 2003 | 05:17 PM
Car: 84 Z28
Engine: 355c.i.
Old Jul 26, 2003 | 06:22 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Use a little WD-40 as a tapping fluid and it will make a smoother thread, sometimes if you tap aluminun with no cutting fluid it will tear the thread.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
