I have a non-thirdgen GM problem
Old Oct 16, 2000 | 03:44 PM
PhantomF4's Avatar
with my 96 Chevy truck. It has a 5.0l engine with the OBD II diagnostic stuff. What it is doing is it acts like it has a miss at low RPM under load or steady throttle. Faster engine speeds alieveiate this. It idles fune(No miss at idle) and it has not turned on the SES light.
Sunce I know -0- abuout OBD II, hopefully someone that does can tell me where to start looking......
Old Oct 16, 2000 | 10:21 PM
PhantomF4's Avatar
TTT
Old Oct 17, 2000 | 06:51 PM
Vader's Avatar
F4,
OBDII should diagnose any misfires. You might not get a MIL lamp, but the DTCs are probably set in the PCM memory.
It sounds like you might have a weak ignition or lean cylinder at idle. One or two injectors that don't flow quite properly can cause this. You may also have weak spark at a couple of holes. A slight vacuum leak can also cause lean miss at low RPMs.
Idle under no load would be fairly stable, but loading at low RPM would cause a noticable "miss".
Unfortunately, there is no "jumper wire" method to retrieve DTCs from an OBDII PCM. You need to connect a serial reader to the ALDL to read stored codes and operating parameters.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 17, 2000 | 11:44 PM
PhantomF4's Avatar
I was afraid if that....
Old Oct 18, 2000 | 08:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Next time you are at 1/4, put some GM port fuel cleaner in your tank, and run it down to "E" and see if that does't help. These engines are known for there Poppet nozzle deposits that build up and effect drivability. Also, make sure things like your plugs and wires are OK. You will notice your distributer cap looks a little funky. It is the HVS distributer, but are subject to the same quirks as any other ignition system.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 19, 2000 | 09:38 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
few things you can check, but i'd start with the coil wire. there is a campaign on it for rubbing through and causing missfire at high loads. gets worse as it wears more. just one place i'd say to start.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
