What are the sign's of bad vavles or misadjusted vavles?
Old Oct 3, 2000 | 04:56 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What are the sympthoms, (spelling) will it act okay while idling and then mess up and higher rpm's or will it be the other way around, please give me all the details you can. thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 4, 2000 | 08:16 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Get yourself a vacuum guage to verify you have bad valves. On the guage, the reading should be steady, if it is irratic, then your have one or a couple bad valves. The guage can be aquired from any auto parts stores for around $30. Very good investment.
Oh, to answer your question directly ... poor driveability and loss of power.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Oct 5, 2000 | 06:39 AM
BLACK Z's Avatar
Car: 86 Z28
Will the car act the same even if it had mis adjusted vavles as it would if the veavles where shot?
Old Oct 5, 2000 | 11:28 AM
MRZ28HO's Avatar
Engine: was: L69
Do you have hydraulic lifters? If so then no. Unless you tighten the rockers really tight, instead of setting the correct lash. Valves are not adjustable, lifters/lash are.
Old Oct 6, 2000 | 06:46 AM
BLACK Z's Avatar
Car: 86 Z28
The motor is a 85 and older gm replacment.
Old Oct 9, 2000 | 09:29 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Oct 20, 2000 | 06:44 AM
BLACK Z's Avatar
Car: 86 Z28
Is lash what they talk about when they say they needed to adjust there vavles then?
Abubaca
Nov 5, 2016 12:22 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
Racerx974
Sep 19, 2015 10:16 AM
gta892000
Sep 16, 2015 12:40 AM
dimented24x7
Sep 6, 2015 03:51 PM
