what springs for L98 heads?
Old Jul 28, 2003 | 08:32 AM
billb's Avatar
What springs are you using in your L98 heads? What are the valve spring diameter? I am looking at purchasing a set of L98 heads, but want to run a cam with .490 lift.
thanks as always:lala: (I like this lala guy)
Old Jul 28, 2003 | 10:51 AM
ede's Avatar
ede
1.25 is the stock diameter it may be hard to get a good set of springs to go .490. i'd machine the spring seats to a larger diameter and get rid of the pull out studs and go with screw in. i'd also trash the factory rotators and buy aftermarket retainers.
lt500r55
Sep 1, 2021 01:30 PM
mrestrictrplate
Aug 27, 2015 11:54 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
