Heads?
Old Jul 28, 2003 | 09:10 PM
mattkenna85's Avatar
Heads?
I want to know if any one can tell me what cc my heads on my 89 camaro with a LO3 engine in it or can some one tell me where to go to find out this info
-thanks
Old Jul 28, 2003 | 09:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Welcome to thirdgen.org.
Your 305 would have come with 58cc combustion chambers.
Old Jul 28, 2003 | 09:48 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
In the future you can go to www.mortec.com
The casting number for the heads is on top, under the valve covers.
The last three numbers of the casting number for the block can be found on either side just behind the motor mounts.
On a block that's older than 1986, the casting number is also on the back of the block where the trans bolts to the engine, on the driver's side.
On an '86 and newer block, it'll be on the passanger side. Although on the driver's side there will be either a 5.0L (305) or a 5.7L (350).
Peak through between the firewall and the engine. You may have to wash some crud off the numbers in order to read them.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
