Throttle position sensor?? code 13+22
Old Jul 31, 2003 | 11:39 AM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Ok I checked my codes, Im getting *I think* a code 13 *1 long - pause 3 short* and code 22 *2 short pause 2 short*....This is oxegen sensor/TPS and TPS. Both of these seem to point toward a faulty TPS. I have a 91 305 TBI Camaro RS, I think has a non adjustable TPS. Have been having bad problems with idling. Doesn't want to stay alive without revvin gas for a bit while I first start it up and has bad idle in any gear or park when stopped. Stalled a few times while stopped especially at startup. DOes this sound like TPS? If so can I just buy a new part and put it in, how hard is it and will I mess anything up? LoL I am not too experienced. Could be oxegen sensor dead also I guess? ANy tips?
Old Jul 31, 2003 | 12:27 PM
DrDuke's Avatar
I posted about a code 22 a while ago and havent gotten a single reply. I am sure it is the throttle posistion sensor, and have new one ordered and should have it on friday. I will see if that makes a diference. the problems you are having sound similar to mine.
Old Jul 31, 2003 | 11:07 PM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Well...update. I replaced the TPS today with a new one, same problem. It hasnt stalled yet and seems a bit more controlled, but idle still very sporatic. Any other guesses? What would cause this? What can I clean or test or anything? Any help appreciated.
Old Aug 1, 2003 | 12:56 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
if you cant get a reply here go to www.camaroz28.com and use their message board. Good for small stuff like that. I use both boards can never have too many resources.
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
