Will removing my cat hurt my car?
Old Oct 22, 2000 | 07:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
on a 350 TPI
Old Oct 22, 2000 | 07:50 PM
Vader's Avatar
Mkos,
The only potential problems I can forsee would be the obvious inability to pass a visual emissions inspection and possibly that the reduction in exhaust pressure could contribute to a nuisance Code '32' for EGR failure at highway cruising speeds. This would only be the case if you have a positive backpressure EGR valve, and even that may not cause the problem if you're lucky. If you're in an area that does not currently require emissions inspections, you shoudln't have a problem with that, but I'd advise saving all of the removed parts just in case. Just throw them in a box in the attic of the garage so they are available when you need them. If you still have the vehicle when the air police finally come to your area (not IF, but WHEN) you won't have to scrounge for replacements.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 22, 2000 | 07:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
We have heavy emissions here, but i am getting collector plates for my car next year, so that means no E-Chek or anything else.
Old Oct 22, 2000 | 08:55 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Haven't had one on my '89 IROC for 2 years. Have yet to get a trouble code from it. Fortunately, we don't have emissions inspections here in Indiana (yet).
Car was quicker after I removed it, but that could be due to how old the cat was and it's condition (didn't really check it to see if it was bad).
Sparks a flyin'
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
Old Oct 23, 2000 | 06:29 AM
DEEPSOUTH90RS's Avatar
YOU SHOULDNT HAVE ANY PROBLEMS. MY CAT CLOGGED UP ABOUT SIX MONTHS AGO, SO I HAD IT CUT OFF.EVERYTHING HAS BEEN FINE(EXCEPT THAT I GET THAT EGR CODE,DONT KNOW WHY)SINCE.YOU SHOULD PICK UP SOME POWER TOO.
90 RS
T-TOPS
3.1 V6
RUNS STRONG AT 187,650
ON ORIGINAL ENGINE
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 13, 2015 07:36 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
