pcv valve question
Old Aug 1, 2003 | 02:46 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
pcv valve question
ok guys my pcv or is it pvc i dunno lol. well i have it going into my passenger side valve cover, they are edelbrock sig. series if it makes a diff. well the pcv is running into the big vacum port on the front of my edelbrock carb and i get oil out of the valve or gromet around it. it seems to spray when i drive it and get my wires and valve cover dirty. now is this a bad valve or sumthing? when i put it in i was doing my motor swap so its got like 3000 miles on it. i didn;t know wut one to get so i went to pepboys and got one that fit in the gromet. can this be the problem?? thganks guys
Old Aug 1, 2003 | 03:32 PM
Morley's Avatar
You need baffles in the valve cover for the PCV (PCV= Positive Crankcase Ventilation, PVC= PolyVinylChloride) The baffels will keep the oil out of the PCV, I think Edl. sells baffels for their valvecovers.
Old Aug 1, 2003 | 05:36 PM
Car: 89 Formula
Engine: Carbed 5.7
well it has like a internal box with vents in it inside the hole where the pcv goes. when u say baffle wut do u mean? does it look like a breatherbut a pcv goes under it??
Old Aug 1, 2003 | 05:52 PM
Morley's Avatar
That's the baffle. try running the hose to a manifold vacuum source and see if that helps.
1992 Trans Am
May 10, 2023 07:19 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
