will a s-10 manual work in an f-body?
Old Oct 23, 2000 | 03:02 PM
Tas's Avatar
Tas
I was wondering if a 5 speed from a 4.3 s-10 would work in an f-body. what kind of 5 speed is it? think its a t-5?
thanks
Tas
-Tas
'89 Formula WS6
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Oct 23, 2000 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No it will not. The trans mounts straight up in the truck but is rotated in the F car, so the shifter and trans mount will not work right. Additionally the shifter in the S truck comes out of the tail housing about 5" to the front of where it does in the F car.
It is however a T-5. So you could in theory swap over the parts (ext housing and inspection cover) from the F trans to the other and make it work, I think; that is, I believe the mainshaft is the same length. Basically they're exactly the sam, except totally different.
Old Oct 23, 2000 | 04:26 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
yes, however the bellhousing will not work, youll need to find a donor belllhousing from a fbody, as the tranny is mounted at a weird angle for ground clearance...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
