Smog Pump and Emissions Question ? ?
Old Aug 4, 2003 | 02:22 PM
nathan2003's Avatar
Car: Camaro
Hey Guys I have a 1991 305 , TBI and I am wanting to rid of its emissions. Someone suggested to me to go and cut off all those metal tubes that recurculate air and just weld them shut or put bolts in them and then I can rip out all the hoses and tubes and really clean up the motor. I don't have to worry about emissions testing and so forth so this will work for me if I can do it. I was wondering if this will work and what I'll all have to do to make it work, and because like a bunch of those hoses come together to this one plastic connector which has a vacum line running out of it... so would i be able to just block the vacum line off ?? and that whole assembly right behind the A/C there take all that out... this is just a thought right now and I need some major input here on if it will work what i'll have to all do and so forth.. your input is greatly appreciated thx alot....
oh ya one more thing..... when i turn my A/C on the ****er just squellls really loud and the car goes into a rough rough idle like it is ggoing to die... then after a bit the squealin will stop and it will be fine... sounds really bad and almost kills the car... any ideas ??? thx..
Old Aug 4, 2003 | 02:49 PM
nathan2003's Avatar
Car: Camaro
anyone have any idea .... ??? any one tried this to your car... feed back please
Old Aug 4, 2003 | 03:28 PM
Joeboy's Avatar
You can eliminate the smog pump easily. Those Tubes attached to the manifolds can be taken off and the holes plugged with plumbing brass squared headed pipe plugs from a hardware store.I think its 1/4' threads. Is it a serpentine belt or a V belt. The manifold vacum port can be plugged up and all those hoses etc that pertain to the smug can be taken out. Including your charcoal cannister (that black can up by your driver side headlight) Just Trace everything that comes from the smog pump and Triple check it all before you remove anything.
Old Aug 4, 2003 | 03:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
also instead of just plugging off those crappy restrictive stock manifold now would be an excellent time to add headers
Old Aug 4, 2003 | 10:05 PM
nathan2003's Avatar
Car: Camaro
Hey,, alright so this is all going to work just make sure everything is blocked up and covered.... ??? you asked about my beltt ?? i have a serpentine belt ... so any ideas about my A/C anyone ??
also does riddin of all this emissions **** make a noticiable differance in the car... or am i just cleanin up the engine when doing this
Old Aug 4, 2003 | 11:20 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
You can do away with it all if you want to. Like mentioned above the air tubes at 1/4'' pipe thread. You could be able to find the plugs about anywhere. You can reroute your belt like mentioned in the tech article. Its real simple...all of it comes off without even throwing a code.
Old Aug 5, 2003 | 01:18 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I agree... mine all came off and the car didn't complain at all... my engine (for a lack of hoses, wires, and general junk) rivals my cousin's '52 Ford truck, lol
Old Aug 5, 2003 | 09:02 AM
nathan2003's Avatar
Car: Camaro
alrighty guys thx alot for all your input on this,, I think that is going to be my weekend project to start tearing into that ****... i'll let you know how it goes... again thx for the input,,, does anyone know what size of belt i'm going to need now since i'm rerouting it ???? I have serpentine...
Old Aug 5, 2003 | 11:11 AM
Joeboy's Avatar
If you just take out the smog you can reroute your current belt and youre fine. If you take out smog and AC you will need a smalller belt. I dont know what size.
Old Aug 5, 2003 | 12:02 PM
Vader's Avatar
Are you expecting to gain some power of fuel mileage from the project? If so, let us know how it works out...
Old Aug 5, 2003 | 01:33 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
no idea what its going to do for your power probably add 1-2 hp but nothing special. One of the big things emissions wise is the egr id look at ditching that that might give you a bit of a hp boost. Man you are the luckiest person ever id kill to not have to pass emissions tests. Tear out smog pump, egr, cats just gut it all it will save you a bunch of weight and would almost certainly net you some form of hp boost while cleaning up your engine bay. The only thing to watch out for is they are slowly incorporating emissions tests everywhere so id do some research because there are some places that dont have them now that will have them in a few years.
Old Aug 5, 2003 | 02:23 PM
Air_Adam's Avatar
I didn't really gain anything by taking mine out I dont think... its isn't faster and mileage didnt really change... I took it all out just because the less stuff there is, the less can go wrong.
Old Aug 5, 2003 | 09:55 PM
nathan2003's Avatar
Car: Camaro
hey thx alot for all the feed back i'll be sure to let you all know how this turns out... should all turn out for the best... and by the way i live in the middle of shindig IOWA... rural america... the heartland.... so weve never had emissions test and we got tractors out here boarin out more fumes then the cars so i think i'll be safe to roll.... for saftey reasons though i think i'll hang on to all my parts so in case it does ever make it this way i'll be safe... so HOW am i suppose to reroute my belt then if i take it off the smogger.... ??
Old Aug 7, 2003 | 04:45 AM
Joeboy's Avatar
There's a tech article on it. Look at the picture then look at your car. Then repeat 40 times and youll understand. Thats what I did.
Old Aug 7, 2003 | 11:03 AM
nathan2003's Avatar
Car: Camaro
ya i'm workin on it man its a pain in the rear on the passenger side of the motor... i'm not sure if i'll be able to get all those tubes off without pullin the header out or somethin... dang ... i got driver side all taken off except one striped out so i cut the pipe and welded her up..
Old Aug 7, 2003 | 11:45 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
I agree w/ 89 RSPower about getting new headers. You won't have to buy the expensive smog headers, and you will be able to take off the manifolds for more room while you work on the emissions stuff. You will surely notice a difference then.
Man, no cats needed. You are a lucky man.
italiano67
Dec 11, 2016 09:21 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
Street Lethal
Aug 12, 2015 11:33 AM
