Who at GM designed the 305?
Car: 91RS
Engine: 305tbi
Originally posted by kfoley
400hp from a 305 is asking alot, you can make 330 or so for about $400 or so, but 400 is gonna be costly and it probably won't have very good street manners.
I think you forgot a zero.
The 305's are pretty tuff too, you can beat the hell out of them and they keep going.
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Well Ive been watchin this thread for a bit and Im not surprised to see the 305 get dissed like it does, but Im equally unsurprised at the praise it gets.
If the L98 were never created for use in the vettes and fbodies ( it almost happened) the 305 wouldve seen alot more respect. The baddest factory 305 put out 230 hp and 300 tq which is very respectable even compared to stock 350's in the muscle car days.
Look at the power #'s of the 350's of 1970 for example: there were 3 available in an fbody, a base like 350 with 270hp, the L48 with 300hp, and the big daddy Z28 360hp 350 built similar in fashion to the 302 of the day. These numbers all look bad assed until you realize they are all estimated in SAE GROSS which was the norm of the day.
If GM was still using the gross standard when the LB9 (L98 cammed) was at its peak the numbers would be around 290-300hp and 340-350tq and of course the L98 wouldve been even more impressive looking.
Of course the 350 is better and has more potential than the best 305 from the factory but there were better motors than the 350 as well. People dissin on the 305
dont be so ignorant would ya?
dont be so ignorant would ya? Member
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Some of us don't need to drag race at every light
I personally don't need gobbs of hp. As long as my little 305 can make me accelerate fast enough to merge into traffic and still get my heart racing when I decide to open up the throlle on back roads I still have a s**t-eating smile on sunny days with the T-tops off. I like getting better gas mileage. There is nothing "wrong" with my 305 other than it could do better.
If I wanted something to race or make sure I smoked the r*cers, I would buy the new GTO. I'm over 30 now and have no need to use my car as a phallic symbol.
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Originally posted by PyRo9862
$400 for 330hp from my 305, sign me up
Total that up and it comes to $455, so close enough really. It's cheap for me because I'm doing all the work and I found good deals on parts.
bigals87z28, would you mind posting up that build, or linking to it? I'd like to see what combo they're running.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Originally posted by pre
Why is even allowed on this site all he does is bash GM and third-gens and talk about the mighty power of his beloved rotary engine.
He as a person is non third-gen related.
but obviously you haven't really seen much of me around the boards if that is your opinion of me
also with 2800 post I really think if all I did was sit here and talk about how my rotary motor is better and bash GM product that I would have been kicked out of here unless the mods/admins are really stupid
so either the mods are stupid or what you say is wrong
you do not really know me as a person so I think the "he isn't even thirdgen related" comment wasn't right on but rather WAY of the mark
can't judge a person only by what he drives to make assumtions like that
57 yeah I know the 305 does have some nice things going for it but to me for a performance motor it isn't really there
emissions and gas mileage though it does do fairly well and can't complain much there.
and haven't read the article yet since it is all fuzzy and haven't been to the store
but I plan to soon
but yeah I will give the long stroke design of the 305 does help with low speed intake velocity which really does help gas mileage and for what was around yeah it wasn't that bad I guess low 15's high 14's but eh....
just not my motor
would rather have something a little more of a short stroke big bore motor
Transmission: 4L80E/4L80E
No, I meant $400. That is assuming you have a good stock bottom end (a rebuild of the shortblock isn't included in this price). Here's what I'm doing to mine: Port heads - free, cam/lifters/springs/retainers - $100, steel shim gaskets - $40, holley intake manifold - $35, holley 650 dp carb - $150, gasket set $40, perf fuel pump - $40.
Originally posted by rx7speed
I'm not going to argue with you about this
but obviously you haven't really seen much of me around the boards if that is your opinion of me...
...so either the mods are stupid or what you say is wrong
but I plan to soon
but I plan to soon
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The Chevy 350 attitude on this board has really jaded me.
Its beyond ignorant as it seams to be the default answer for any question.
"put a V8 in it"
Even if you own a 305.
Don't fix this, don't mod that "put a V8 in it"
[cough350cough then stroke it]
Squashing peoples individual creativity should of been left on the school yard.
Thinking out side the box is human.
I luv my 2.8
"put a V8 in it"
I luv my 2.8
Car: 91RS
Engine: 305tbi
The general attitude ive seen here is the correct one. If you want to go faster put in a bigger engine its going to give you the most hp/dollar. But if someone wants to build a 5.0, 3.1, or 2.8 there are plenty of people willing to help. Someone just always chimes in and says its going to be cheaper which is correct in most cases to put in a bigger engine. Havn't seen anyone on here building an Iron Duke though. That would be interesting.
Car: transam, el camino
Engine: 415
You guys sound like a bunch of ricers trying to justify your 4bangers
"smog and gas mileage" is stated every other post.
If they had made anything better than a 305 for an engine, this post would be about "who designed the tranny?" or "who designed the rearend?" Face it if GM gave us a destroked 400/T56/12bolt combo from the factory you would complain about the brakes not being up to snuff, or yadda yadda... I guess what I am trying to say is stop whining or get off your @$$ and build a streetable 305 with vortec heads it wouldnt be that hard.
As for the 151c.i. Iron Duke, I too would like to see someone mod it. They can handle a ton of boost stock and a 4barrel intake would make nitrous an easy enough thing. Imagine running with the stock 4cylinder fbody at a track 250hp nitrous shot, who cares if the engine blows, junkyard has a zillion of them!
"smog and gas mileage" is stated every other post. If they had made anything better than a 305 for an engine, this post would be about "who designed the tranny?" or "who designed the rearend?" Face it if GM gave us a destroked 400/T56/12bolt combo from the factory you would complain about the brakes not being up to snuff, or yadda yadda... I guess what I am trying to say is stop whining or get off your @$$ and build a streetable 305 with vortec heads it wouldnt be that hard.
High compression and crazy cam with horrible streetability you say?
Here is the link
http://www.hioutput.com/tech/400hp/400hp.html
What were you saying about the cam? 10.6:1 unstreetable you say?
Thats what I thought. You know, I have no problem with the 305 bashing, but unless you have done it or tried to do it, dont say it can or cant be done.
Here is the link
Dude, it's not "305 bashing". It's "reality". And yes, that's the article that we're talking about.
I have a problem with people that read a magazine article and become instant experts. Have you ever actually driven a car with an engine like that in it, especially one that weighs over 3500 lbs? Well, I have, thank you very much, in the form of a SBC 302. Not just driven, but driven daily, as my only vehicle, for 2 years. I suspect you were born after I sold that car (were you born after 1978?). And, for the record, I prefer my current 305 for daily driving.
There's a wide gulf between magazine articles and real-world experience. Yes, they used the word "streetable" in the article. So? There's also a big difference between being able to drive something on the street and driving it daily.
Car: IROC
Engine: 350 TPI w/modifications
Transmission: th700r4 built with a vig stall
simple answer as to who designed the 305
an idiot
an idiot
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Originally posted by BlackcamaroIROC
yip, instead of destroking their 350 for insurance purposes and a "smaller" V8...
bigals87z28, I don't call a 244* cam in a 305 streetable. I call that a hand full.
Car: IROC
Originally posted by Tom 400 CFI
They didn't do it for insurance purposes. Go back and re-read this thread for the real reason. (hint: better emissions & and fuel economy, while retaining some low end grunt).
yip, instead of destroking their 350 for insurance purposes and a "smaller" V8, GM de-bored it. I bet with TPI and the cam profiles available but larger valve heads, a 302 would've upstaged the 350 TPI, so perhaps that's why they didn't bother with it.
Going from gross HP to net was an attempt to end the "horsepower wars", and the insurance companies were involved in that. But, the real reason for the 305 was the EPA, with both emissions restrictions and CAFE, while maintaining some "seat of the pants" V8-ness (at least in the lower RPM ranges).
TPI on a '67-'69 vintage Z28 302 would be a HORRIBLE combination. Current LT1 induction, modern heads and a modern cam - perhaps. But, TPI is still a much better match on a 305 FOR THE PURPOSE OF ACHIEVING THE ORIGINAL INTENT!
I'll say it again: If you haven't read the Hot Rod article on torque & HP referenced above (or don't at least have an appreciation for the topic), you CANNOT understand why the 305 was the proper solution for the times.
Car: IROC
Originally posted by pauldaniel26
And a 305 TPI is just as clean running as a 350 TPI.
. my 350 went by with half the acceptable level of emissions. five7kid, fords intake manifold doesn't choke off the 302, and I'm sure an Lt1 outflows it. TPI is a good design with a lot of room to work with. but GM dd what they did, no sense in debating the past. opposing view points have gotten a few members on my case already
There are plenty of reasons for an engine to run "dirty" and have poor fuel economy - one leaking injector being a possible explanation. Being a 305 or 350 is irrelevant. My engine with its performance mods came out cleaner with 47k more miles on the engine than it did when it was a stock LG4 - passing against the V6 standards, as a matter of fact. Are you saying putting in a 350 would make it even cleaner?
Ford 302 intakes are irrelevant to 305/302/350/TPI discussions.
I never said TPI is a bad system. I said it would be a horrible system on an original SBC 302 - what I should have said is "as delivered from the factory" (although it is possible it could "work" with extensive mods - basically none of the factory stuff left except perhaps the fuel rails).
Car: IROC
Engine: LT1, L400
Man this thread is retarded.
The reason for the 305 was for low emissions, decent economy, and good low end grunt -like five7kid said above.
It's easier to achieve good emisisons with a smaller bore. That's a fact. If some goon on this board knows of some 350 that tested cleaner than some 305, all that proves is... NOTHING. It indicates to me that that goon's 305 is in a worse state of tune, has more or less miles, has a different hisory, is using different fuel, etc, etc. Talk about a UNCONTROLLED experiment -lol.
I don't know who at GM designed the 305, or more accurately, decided on that bore/stroke combo, and I don't care.
I don't LIKE the 305 personally, and I won't ever be putting one in my car, but there are specific, concrete reasons why that bore/stroke combo was utilized. The reasons above are why the 305 came into existance. Arguing otherwise is a waste of board space.
"305 and low end grunt can't go together rofl"
No one ever said the thing would be a torque monster. COMPARED TO THE ALTERNATIVES, (do you know what the alternatives were?) the 305 could produce some decent torque.
I agree completely with five7kid:
"the 305 was the proper solution for the times"
Car: '86 IROC-Z
A better questin to ask is who designed the LG4?
There are plenty of good 305 motors conbinations. It seems some of the configurations are particularily offensive, but not the block. I only see people complain about combinations like the "peanut cam" in the LG4.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
