1992 rs stalled, now won't start
Old Oct 24, 2000 | 01:44 PM
1992rs's Avatar
Ok, a couple of weeks ago my bro's RS is having some problems. He was out and his car would't start. He got his car jumped and it started. Well the next couple of days his car would start on it's own, but a couple of times it had to get jumped. Well, he replaced the alt. then the other day the car stalled in the middle of the road, he got it jumped and started, and got it home and it stalled again. Now if you try to start it on it's own, you can hear the started engage and it makes a clicking noise, but the engine won't do a thing, won't turn over nothing. Battery volt is down to 10, he also said that before the car stalls the bat. gauge drops down to around 8 then it dies. Any Ideas? New battery? Short somewhere? Thanks for the help.
Paul
Old Oct 24, 2000 | 03:41 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hmm well if it doesnt start on it's own, he needs a new battery, as for the stalling, it's weird if the voltage drops that's the alternator
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 24, 2000 | 11:27 PM
1992rs's Avatar
Well I got it figured out, the plastic terminal were the postitive wire from the battery goes to meet a bunch of other wires, well all of those wires were coroted (spelling?) The nut that held them on was rusted and a little lose, so that caused alot of resistance, causeing voltage to drop, car to stall, unable to start. But I do think the starter may be going bad too. Well I won't worry about it till he is stranded again!
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
