Help with thump during acceleration...driveline???
Old Aug 6, 2003 | 03:21 AM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
Hey, I got the 87 GTA, all stock but a Hooker catback. It recently started making a weird thump when you accelerate from a stop. It ony does it at less then 10mph or from a stop. It sounds like something jerking and you feel a kick coming from under the car near the passenger side, like right under their ****. If you idle it and very very slowly roll onto the throttle it won't do it. But if you step on the throttle like even a quick tap it will do it. I've tried reverse, and doing a hard downshift but like I said it only does it from a stand still or right off the line. Any advice on what it could be would be awesome!! Thanks guys
Old Aug 6, 2003 | 03:36 AM
thecoolone's Avatar
Car: 89 GTA
even though it doesn't do it on a hard downshift, I'd still have to say it sounds like a tranny mount.
Old Aug 7, 2003 | 06:26 AM
IROZINCO's Avatar
Thump on accelerating
Sounds like an absolute CLASSIC case of tranny mount failure to me! Fix it, it's only gonna get worse.
Old Aug 7, 2003 | 11:53 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Yup, tranny mount
Old Aug 7, 2003 | 01:14 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
if its not the tranny mount (but it probably is) then it could be the motor mount on the passenger side, the way he described it under the passenger seat it could be the cat hitting the floor
Old Aug 7, 2003 | 03:29 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Its probably the tranny mount. Change it...7$ at a parts store. Should be an easy fix.
Old Aug 7, 2003 | 04:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by Tom91Bird
Yup, tranny mount
this man knows these tranny mount things
Old Aug 7, 2003 | 06:38 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I vote tranny mount, but look at your engine mounts and your u-joints while you're at it just to make sure.
Old Aug 7, 2003 | 08:11 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Very funny j/k
Old Aug 7, 2003 | 08:46 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Get a polyurethane trans mount. They are more expensive but will not require replacing again.
db057
Aug 22, 2015 08:17 PM
breathment
Oct 27, 2003 09:52 AM
breathment
Mar 29, 2002 07:07 PM
Eightyninef
Oct 4, 2001 09:28 AM
breathment
Sep 23, 2001 04:42 AM
